Disables the sending of messages to the console display.
In a stack, this command is applicable only to Master and Backup nodes and not applicable to the standby nodes.
Disabled.
If the log display is disabled, log information is no longer written to the serial console.
This command setting is saved to FLASH and determines the initial setting of the console display at boot up.
You can also use this following command to control logging to different targets:
This command is equivalent to disable log target console-display command.
The following command disables the log display:
disable log display
